I'm looking for help understanding whether my grid tied SMA PV system with battery backup is operating correctly during grid down events.
Observation: When grid is down / disconnected, the Sunny Boy inverter (on a sunny day where PV is generating (3000+ W) will not sync to the local microgrid created by the Sunny Island. The Sunny Boy shows AC Frequency error, indicating it cannot get a frequency within range from the Sunny Island microgrid.
This occurs when battery bank is at @90% or higher state of charge, the Sunny Island indicates it is in the "Float" charge state, and when load on the microgrid is about 1000 W. I have not taken the battery below 90% to test if / when the fault clears itself. In other words, when battery is sufficiently depleted that charging is required, it is possible the Sunny Island will allow a connection to the power coming from the Sunny Boy. I don't know that yet.
So, the question is whether this is normal / expected / designed behavior? Should I expect the Sunny Island to prevent syncing with the Sunny Boy until the battery is sufficiently depleted to change from "Float" to another charge state? Of should Sunny Island and Sunny Boy be always in sync regardless of State of Charge and the excess 2000W of power generated by the PV to be shed other than by a complete disconnect between the Sunny Island and Sunny Boy?
Thanks.
Thanks.
