I got one. Arrived at 85% charge, good. All systems worked, incredible packaging-- thick 2" foam all around, super thick cardboard, and double boxed with it too.
Works well, tested both dc/solar inputs. The bluetooth phone app was fast and easy to work.
Of note, they have an owners manual on the app, it has been updated to show 12v to 25v for the one dc input, instead of 18v, and now says don't exceed 25v PV voc. Hobotech actually tested it to 28v. This is good, as you can now do solar from 12v to 95v input pretty much.
Additionally, the dc output is regulated to 13.4 on the 30A xt60 at least, tested on Jasonoid this month. This is fantastic, because it means you can use the e1500lfp to charge other lifepo4 batteries to 80% SOC! Many solar gens could only get other batteries to 20%. This lets you use a cheap Lifepo4 as an expansion battery instead of their expensive one.
I have looked at 20 or so power stations in the 1000wh to 2400wh range, for use in truck popup camper systems as the central core. Ecoflow, Bluetti, Yeti goal zero, and Anker. IMO, none of them are as good for this purpose as the Pecron e1500LFP.
They lowered price on expansion battery to $1100. And latest pics appear they took advice from ReeWray and Hobotech reviewers, and improved its form factor size. Take a close look at it, 3072WH so 240Ah at 12.8v. It has another 400w solar MPPT input controller that can be used solo or when connected, and it has another 30A 12v dc xt60 output, usable at same time when connected too. So with the e1500LFP, that is 60A of 12v dc, actually 13.4, to power your dcbus, really good. Even today, straight 230Ah 12v battery is $620 for 230ah, little bit less than the 240ah in the expansion. For $400 over the price of the battery, I think the dc ports, mppt input, etc. Makes it a good deal.
