blasetheodore
- May 4, 2022
- 3
I tried searching the forum before posting, apologies if I missed it.
I'm trying to understand how 'Constant Current' & 'Constant Voltage' charging phases (from solar chargers) are affected by realtime draw on the system (i.e. inverters, fridges, etc).
And if the draw-during-charge affects the batteries negatively, is there a way to isolate the charging from the drain to prevent it?
I'm also confused by what equipment actually determines those CC/CV phases. I always thought they were controlled by the charge controller. But I've also read that the battery BMS affects the CV phase by limiting its draw. If this is true, is a phase mismatch something that would cause problems?
Lastly (and possibly most relevant) does 'constant current' imply a fixed current? Or does it just imply a 'maximum' current?
In other words, what happens when a cloud comes by and the solar charger stops charging?
In case it matters, I have 3x 100ah LifePo4 batteries (=300Ah @12v). Which I believe gives me 300A combined max input current.
And that is fed by a 60A MPPT controller (max 1200W, min 0W).
And the battery is connected to a 3000W Inverter.
