No long (over 1 day) outages here since I put in the Solar in 2021.
But many years ago a hurricane took down the neighborhood power for 2 weeks,
we only had the generator at that time, used it carefully and did not run out of fuel.
We are on a well, no electricity-no water.
Solar runs the well pump.
In the event of solar failing or batteries can't be charged,
the Diesel genset will be used.
I store 6 - 55 gallon drums of Diesel for hurricane season.
The water is only about 50 ft. down the 4” well casing.
Thought about buying a manual hand pump to replace the electric pump motor
in cases of no electricity available under the worst case.
But there is no way to get the well pump out w/o a crane.
Don’t have a crane.
Need 6-8 tons to drag the pump up through the pipe rust & crap.
Swimming pool w/ 16,000 gallons, could be used if treated and filtered.
Have a couple of the MSR Guardian Purifier systems. Slow, but effective.
Have 6-55 gallon drums of water stored in a spare room in the house.
Lake within walking distance, would need some lakefront owner's permission to obtain water.
Not sure what else I can do to prep for water.
Very hot here most of the time, hydration is critical.
Water heater is on solar power.
Range is not on solar (grid only), so we would have to use the BBQ LP or
RV to heat water for cooking.
Refrigerators are all on solar.
Heat pump is on solar, batteries will run the AC overnight.
Can't run the heat part of the heat pump, the electric heat strips use too much power
for the solar to run.
Could switch the heat pump to generator power, but that is noisy and Diesel is expensive, not available in a disaster.
Have hats and jackets for the couple of cold days here per year.
Have gas & Diesel vehicles, and a bicycle for transportation.
Have an alarm system, but it is not on solar, and the battery would only last a little while.
Cameras on a separate system that is powered by solar.
Tripwires can be set up in the yard to alert us of trespassers.
Septic tank takes care of sewage.
The RV duplicates many living conditions of the house becomes uninhabitable.
Solar has redundant inverters and charge controllers.
We are hoping that all this redundancy is never needed!
