I want to set the controller so it cuts off at 50% DOD for a sealed lead acid battery which is 12.1 volts. I assume that these are the relevant parameters that need to be reset as a 10.6v Discharge limit means its dead!
Low voltage reconnect voltage 12.6V
Under voltage warning reconnect voltage 12.2V
Under voltage warning voltage 12.0V
Low voltage disconnect voltage 11.1V
Discharging limit voltage 10.6V
Thanks for any advice.
