I started with a Ridgid rolling case.
I have the cells set in, and the bms leads all routed and tied in place, protected with plastic corrogated sheeth.
Anybody see anything i need to address so far?
It is only 60Ah, so im not too concerned with arc flash failure. A good fuse will be installed.
I have din rail DC breakers i plan to use. 60A should be fine to cover any surge the inverter can draw.
