Do all your panels ever get full sun or do you always have shadows on them?After replacing one male and two MC4 connectors I have 100 volts running into my 48v Growatt but still no watts are being registered for PV
Could this shade in the top right cause no energy to be generated?
After replacing one male and two MC4 connectors I have 100 volts running into my 48v Growatt but still no watts are being registered.
Starting a new thread that omits all the info already discussed in your original thread is not helpful.
Where is your load?Where do you think the watts would be "registered"? What load do you have plugged into your growatt? Are batteries connected?
In short, do you have any place for the electricity to go?
Batteries are brand new from battleborn. When I look at the Growatt display panels and go down to PV it says 0 watts.
I am trying to run a dehumidifier but it’s not connected cause I figured it will just drain the batteries.
Sparky I show a max charging current of 120amps. I am not sure if that is what you are looking for.
I did run the growatt with the panels in direct sun for an hou today. At which point I got a warning light 4 and beeping.Which according to the manual is lower battery. How can I get my panels to charge my batteries?
