Oneorangedog
Hi, a couple of years ago I built a 3.36KWh 4S 12V power pack with a victron inverter and charge controller included, for an offgrid woodland cabin.
Everything has been fine, but recently I included another 4S string in parallel to increase it to 6.72KWh. It has its own Daly BMS exactly same spec as the original string [though a newer model].
I didn't manage to fully top balance the new 4S string before taking it all to the cabin - I tried, but after 4 days at 10A it only got to about 75% SOC.
Now, when charging it only charges the older string. It gets to 95% and moves to "float", but the other string is still only at 60% and does not increase charge
I also have both strings connected into the victron shunt - but that has stopped sending data/connecting to the victron app... maybe not a related problem.
Here are some pics... [since reading some other posts on here I am considering upgrading to Class T fuses now... The cabin is only a store area, but I can't afford it all to burn down!]
Thanks in advance,
Thanks in advance,
