Donald Siegel
- Sep 24, 2019
- 78
I have two Renology 12v 200 amp gel batteries in series used with a 24v MPPSolar all-in one. The battery spec sheet shows a full charge at 12.8v or 25.6v for my two in series. They recommend to discharge to 50% or 12.1v/ 24.2v for my batteries. I have a hall effect meter. While bulk charging the inverter and the hall effect meter agree pretty well and I will eventually get a "full charge" at 25.6v. If I stop there at a hypothetically full charge, the voltage predictably sags back once the battery is disconnected and rested. It will actually sag back to 0.8-0.9v lower than the peak voltage observed while charging. To get a resting battery voltage and a full charge of 25.6v I need to bulk charge to 26.4 or 26.5v on my two volt meters. The questions. Is it a poor practice to over-charge a battery to 26.5v to get it to a full charge of 25.5v? Is charge voltage overshoot actually over-charging, or are voltage readings while charging invalid? Is a 0.8-0.9v difference in the inverter, and hall effect meters voltage reading while under charge and the final resting charge defined as the battery disconnected and rested 12 hours too high a spread, and a red flag that my new batteries have a problem? I cap my charging at 20Amps, the PIP usually is charging between 8-15amps. Charging for this discussion was on grid.
