I'm building an off-grid Arched Cabin. I need help finding a 4000W+ propane generator with 2-wire auto start. I'm thinking of getting a Growatt SPF 5000W ES 48V 240V all in one. Plus solar panels and batteries.
A propane generator is as close as putting in a propane carb in the gas gen. You will not have as much power, but it runs just the same. So a 4,000 watt gas generator will not likely make 4000 watts running on propane.
They make dual-fuel and tri-fuel carbs that will run on gas/propane or gas/propane/natural gas.
Most gennys are rated at gasoline power output, and propane is a big hit.
The 9500W firnman at costco is 699/999 depending on sales, and it only outputs 6kW on propane.
Even less on natural gas.
