kolek
Inventor of the Electron
- Sep 29, 2021
- 573
This is an older thread but what's the best "open source" alternative to Solar Assistant?
I want to be able to monitor my Deye 8k inverter and JK-BMS
I realize that Solar Assistant can be used "offline" but I prefer open source.
Will this do the same thing?
or this (which was mentioned earlier):
GitHub - slipx06/Sunsynk-Home-Assistant-Dash: Home Assistant Dashboard to display Inverter information. ESPHome configuration to collect inverter sensor data via modbus
Home Assistant Dashboard to display Inverter information. ESPHome configuration to collect inverter sensor data via modbus - slipx06/Sunsynk-Home-Assistant-Dash
github.com
GitHub - HotNoob/PythonProtocolGateway: Python Protocol Gateway reads data via Modbus RTU or other protocols and translates the data for MQTT. In the long run, Python Protocol Gateway will become a general purpose protocol gateway to translate betwe
Python Protocol Gateway reads data via Modbus RTU or other protocols and translates the data for MQTT. In the long run, Python Protocol Gateway will become a general purpose protocol gateway to tr...
github.com
