hello,
i have issue with my off grid inverter 11KW from easun / voltacon (same product i think) and my bettery Lifepo4 bms 10KW
I wanted to start / try the battery and i get a F52 fault bus voltage is too low
my off grid inverter is connected to utiliy and will work like this
solar = > battery => utiliy
when i start the onduleur with only battery (no solar / no utility) it s realy reare that start or will take 5 or 6 reboot
and some time it work without problem.
i tryed to setup user battery , LIC or LIB , sometime it work good for start onduleur and sometime that's not possible
but 100 % of the time , when utility is working and i start the battery i got a F52 error
i wanted to try to use BMS system in RS485 or Can but i do not know how to do , it seen i have to find a good cable or what is the protocole from Inverter
sory for my bad english
but i would like some help
thanks you so much
thanks you so much
