Swamplizard
Ready to unplug and wander the USA
- Oct 21, 2020
- 238
Conversion van has LV2424 (finally working), 2x100Watt flexible solar panels on roof in series, 24v 280AH LifePo4, 240watt 12v to 24v DC to DC converter.
Couple of questions:
1) Fridge is a dorm 120v unit running off inverter in LV2424. When running LV2424 plus fridge seems to consume 100watts/hr until fridge is cold then it cycles and uses much less. The LV2424 uses 25 watts/hr by itself. The two 100Watt solar panels in series are pushing about 100watts 4-6 hours a day so they do not keep up with worst case scenario of 2,400 watts consumption (100wattsx24 hours). I plan on adding two more 100watt panels in series so I will soon have 2S2P and hopefully 200watts/hour to battery 4-6 hours a day. There is no room for more than 4 panels. Hoping to get it to a point where it is a "wash" when parked in FL. If it doesnt work out - how much power do the 12v/24v fridges use? Would it make more sense to use a smaller separate inverter just for the fridge? Would this be more efficient than the LV2424 and its overhead?
2) DC to DC converter is bluetooth but not much info available. It says if it is on or not and what phase of charging it is....no totals. It is connected to 24v main battery connections (fused) on positive and shunt on negative. Should I add a flow meter to it or just trust that it is doing its thing when van is running?
Thanks for any recommendations or thoghts/ideas.
Swampy
Swampy
