meetyg
- Jun 4, 2021
- 1,116
Let's say I have a JK BMS connected to an inverter with communication between them.
Will the JK throttle down the inverter's charging current at a higher SOC, or will it allow the inverter to charge at the maximum charge current set at inverter/BMS ?
The reason I'm asking is because I would like the inverter to charge up at a higher rate when SOC is low, but slower at higher SOC to enable better balancing.
I was wondering if it's worth setting up JK BMS communication to the inverter, which I don't have setup currently.
Thanks.
Thanks.
