silverstone
- May 3, 2022
- 1,041
It does NOT matter. SOC is determined based on coulomb counting (measurement of current & integration over time).and i believe my maths is right becos the voltage is constant - there should really only be a .510 difference between the 2 BMS's
Voltage measurement is NOT an accurate method to evaluate the SOC of a Lithium Battery (let alone if you have some load / current flowing !). Maybe a bit better for Li-Ion, but if you are still in the "flat" part of the SOC/voltage characteristic, a very small voltage difference corresponds to a HUGE SOC difference.
That SOC is reset to 100% (or 99%) if all your cells reach a target voltage & your current goes below the tail current. Similar to Victrom Smartshunt I guess.
So, if your SOC resets to 100% after a full charge, are you sure:
- You did NOT underestimate the capacity ?
- You did NOT set voltages that are too low for absorbtion / bulk ?
I notice a 5% deviation of SOC between my batteries, even though they reset approx. every day (minus the unbalance of battery 02 of course). That could also be to the different version of the JK BMS that is used, inaccuracies in the current measurement of the JK BMS (coulomb counting ...), one cell being lower capacity than the other and thus hitting OVP / UVP earlier etc.
Or also my temporary cabling, causing some current sharing unbalance. The list is big ...
