JK BMS GPS Connector
Bundyblu
Hi
Can anyone inentify what type of connector the GPS Port uses on a JK BMS Type JK BD6A20S10PC
The JK BMS is the new black model.
Would you know what type of connectors the Can (3 Pin) and the LCD (6 Pin) connectors. Thanks
Edit - probably bad info below but I'll leave it for anyone with a JBD.
They look like the same size as JBDs, you'll need to measure and make sure.
I used these, they shipped quick; make sure you select the version you need.
$0.60 | HY2.0 Connector with 20cm 26AWG Cable Wire Butt Connection 2 3 4 5 6 7 8 Pin 2.0mm Pitch Male Female Plug Socket
Hello Bundyblu,
I'm starting a new project to extend to JK-BMS a 6 months logger I made for DALY BMS .
I already found all the protocol info I need to communicate with JK , the only doubt I still have is coming from the DS : http://www.jk-bms.com/en/Upload/2023-12-05/1746328565.pdf
I will use UART connector to be compatible with my current HW.
UART connector is "P5" on JK meant for GPS. Is a 4 pin JST 1.25 ( or it should be )
Pin P5.1 is stated to be VGPS ( ... close to B+ ) .
QUESTION: Have you tested this Pin during your development ? is really B+ ( on 16S it should be around 50V that makes no sense for me )
Thanks for replying.
P.S. asking because I don't have a JK-BMS - I will work blindly this time .... simply trying to add the JK protocol .
For your ( and my fun ) this is a Zoom IN of a 24h log from my logger :) notes - yellow boxes and red arrow are added later
Hello Bundyblu,
I think I found the answer by myself ... :) YES VGPS is B+ , I won't use it . Activity to make my dongle compatible with JK already at a very good point . Stay tuned !
Can anyone identify the connectors used on the new black JK BMS, for the No3 LCD display 6pin 1mm pitch and carries a thin spade locator - NOT JST AFAIK. Mini JST SH 1.0mm Pitch Wire Connector SH 1mm.
I thought the JST GH was closer but depends on the pitch
Wow guys, this JST NSH https://www.jst-mfg.com/product/pdf/eng/eNSH.pdf is a nightmare. the whole 1.0mm pitch x6 is smaller than my pinkie and I would need special crimp tool to assemble a male wired plug. This is a serious issue against JK BMS cos any loss of connector cables means your BMS is a brick.
I got a remote indicator for use on my golf cart but I need ca 2m of cable between the battery and the drivers dashboard. I shall have to cut the cable and insert a 6 core 28AWG cable length etc to make it all work. I am not impressed - this is a fail point in the reliability chain. AFAIK the display also works as switch (replacing the pushbutton assy - with just 0.5m of cable - how is that supposed to be useful other than on a bench or mounted on a battery box?
Clearly there isnt enough space on the board to use the regular JST 2.0mm
