I have a brand new 100Ah Lead Carbon 12v battery. Which I will be using in my boat as a deep cycle for the instruments.
OCV was 12.74V when unboxed.
Manufacturer specs state 14.7V @ 0.1C recommended (0.3C maximum initial) for cyclic use.
So I attached my battery charger set the voltage to 14.7V, and set a maximum current of 10A with a cut off at 1A.
As I expected, the current tapered off very quickly to 1.7A and of course the voltage rose very quickly and stabilized at 14.7V.
But the behavior I did not expect is that the current is slowly rising. Over the last 60 - 90 minutes, the current has gone from 1.7A to 2.21A and appears to be continually climbing.
I had fully expected the current to continue to drop down to 1A which is what I see with my other non-carbon SLA/FLA and AGM batteries.
Can anyone explain what is happening here please?
