My system is a 4048sw trace inverter, trace c40 cc with 1.2 array, and an epever 8415an cc with 1.6 array.
I changed out my aging 20 kw fla batteries and put in 4 lifepower4s. I checked all connections and flipped the breakers on the batteries. All the pretty green lights came on, so I turned on the inverter. The charge controllers sprung to life,so I started changing settings to set up for lifepo batteries. After 5-10 minutes the inverter and ccs shut down. There's no load, no pv connected. Voltage is around 53 volts. The individual battery circuit breakers do not trip. To turn the inverter back on, I turn off the battery disconnect switch, turn off the battery circuit breakers for a few seconds, and turn them back on.
This is the ongoing situation. I've tried various parameters but with the same results. I've tried disconnecting one cc and then the other. The epever always shuts down. The c40 stayed on longer than the usual 5-10 minutes but shut down after I turned loads and pv on and voltage went up (60 volts).
This doesn't seem like a bad connection issue. It might be a epever issue but it might be a inverter issue. Anything obvious? Anything I could test?
