Joshua787
Hi All,
I have a shipping container that I’m building an off grid system for. I have 2, Growatt SPF 5000 ES inverters purchased from Alibaba connected in parallel and a Growatt auto transformer that’s powering an outlet that’s jumping another outlet that’s in a metal box screwed into the shipping container.
Yesterday I finally finished wiring the system and powered the 2 outlets and everything was working fine till I turned off the circuit breaker and later my 5 year old daughter touched the shipping container and got zapped. I grabbed my multimeter and measured from the ground to live wire and even though the breaker that was feeding that live wire was in the off position and disconnected from the panel I showed a reading of 120v. This is extremely alarming because the whole case of the shipping container was energized due to the grounded metal box screwed to the shipping container! That’s an 40’ by 8’ area that’s energized by this live ground. I’m lucky my daughter was not seriously hurt by this.
I wired an independent ground all the way from the ground rod to the subpanel ( panel on the right) that it’s being fed by the auto transformers output wires and I still was getting a live ground reading.
Can anyone help? I need to figure out a solution to this live ground problem.
The picture below shows the 2 growatt inverters powering the panel on the Left.
A 30A breaker feeds the wires going through the panel on the right and straight up into the auto transformer on the “IN” side
On the output side you have the live1, neutral and live 2 wires going straight down to the panel on the right.
Then on that right panel you just have a 20A breaker that’s feeding the outlet on the right that’s jumping another outlet that’s in a metal box screwed to the shipping container.
Any constructive criticism is welcomed as well. I’m new to this Solar world and any suggestions to better my system is welcomed
