rin67630
Hi I had ordered a couple of low power 5A "MPPT" solar charger modules based on the Consonance chip CN3767, specialized to charge Lead-Acid batteries.
The data sheet looked promising: CONSONANCE/CN3767
Beside the accepted fact that "MPPT" means for them "Manual Power Point Trimmer", I got only miserable charge levels with it.
Then, I began to check it thoroughly:
It t never charged the battery above 13,55V and that is not adjustable!
The output never came to absorption, not even to regular 13,8 float charge level, irrespective of what is fed at the input and what charge level was initial
That low voltage will bring every lead-acid battery to sulfation.
I wrote that to Consonance and got this answer the same day:
"The phenomenon you tested is correct. CN3767 has a fixed output and cannot be adjusted.
In addition, the floating charging cycle voltage of 12V lead-acid battery is 13.5V, so the floating charging voltage of cn3767 is set at 13.55v. When a battery with voltage over 13.5V is connected, it will not be charged.
CN3767 for the battery below 12.4V, the battery will enter the charging state automatically when it is connected. If the battery voltage exceeds 12.4V, it may enter into floating charge. When the battery voltage exceeds 13.5V, it will not enter the charging state."
Have those guys at Consonance ever got a clue on how to charge lead-acid, before they began to design a "specialized" chip?
