Let say I choose a 5kw 48v all in one unit.
Now I prefer to run a heap of pannels to make sure even on adverage days I'm making power.
If I want to run 10kw panels am I right to do that with a single 5kw inverter?
I understand it will produce a max of 5kw and that's fine but will it produce 5kw power and also charge my batterys?
Also if I run a few in parrall and want to run 3 indentical battery banks is there a way I can cycle them so they all don't sit at 100% full 90% of the time.
If it helps it will be a fully off grid property and as I work away there is a good chance noone will use power for 10-12 days at a time then on weekend I will use it as i please.
Im looking at 3 banks of 16s 280ah lifepo4 batts. With a smaller SOD range 30kwh~ but I'll also add 3 x 5kw mpp solar pip 5048 inverters. So they should also produce 75kwh but even on adverage days 20kw+.
We also have darn good rebates based on panel array size not inverter or battery's.
System may be overkill but rather size it up to allow full time living there while on holidays ect ect.
Plus I like my ac and hotwater will likely be via heat pumps.
