There is no standard size for mc4 connectors. The different manufactures don't make their products exactly the same.
I posted some links on the problem today on this thread:
Thanks for the link. but I don't see how tnat would do what I have in mind. I use 2 pairs of folding panels in parallel., connected to the Delta by a splitter with MC4 plugs on the Y and the solar plug connection to the Delta. That's lots of MC4 connectors to plug and unplug every time I use...
diysolarforum.com
Rufus
Just to clarify / correct? There is only one manufacturer of MC4 (MultiContact) connectors and that is Staubli, who bought MultiContact, the original inventor of the connector style).
Every ‘MC4’ you purchase from another manufacturer than Staubli or MultiCovtact (if such a thing is even possible these days) is a copycat ‘MC4-like’ connector.
Aphenol calls theirs ‘HC4’, Tyco calls theirs ‘TC4’ (or silo net Jing beginning with a ‘T’ and ending with a ‘4’).
Each variant and knock off uses slightly different mechanical dimensions and tab design and that is why each varient and knock and variant comes with its own set of wrenches (and why one knick-off’s set of wrenches are the wrong size for true MC4 connectors or another brand of knock-off).
So you’ll end up needing a set of wrenches for each variant or knock-off you use.
But the real thing to be aware of is that the UL-listing of these MC4-like variants is only valid when they are matched with identical connectors.
Staubli MC4s are only guaranteed for their current ratings when mated with another Staubli MC4 connector.
Aphenol HC4 connectors are only guaranteed for their current ratings when mated with another Aphenol HC4 connector.
My solar panels had Aphenol HC4 connectors (generally considered the closest in quality & performance to Staubli MC4s) and my Microinverters had a non-HC4 variant.
I had to disassemble my array to replace some faulty Microinverters last January after 7 years and was absolutely shocked to discover that most of my HC4-to-non-HC4 connections had melted and fused the plastic.
Most Microinverter manufacturers such as Enphase now offer variants of their Microinverters with different flavors of UL-listed connectors such as Staubli MC4, Aphenol HC4, etc or sell pigtails allowing you to safely convert from their native connector to any of the more popular UL-listed knock-offs for exactly that reason.
You should always check that any ‘MC4-like’ connector you purchase has UL listing and be aware that any time you mate two dissimilar MC4-style connectors, you have voided your UL listing as well as your warranty and you are likely to get moisture ingress and eventually suffer from corroded contacts and melted /,fused plastic the way I did.
So needing different wrenches got the different MC4-style knockoff connectors is really not the issue to be most concerned about…
