wingedlizard
I am upgrading from a growatt 24v inverter to an eg4 6000xp 48v inverter. I've order 1 48v EG4 LL battery ( 100ah) as well.
My current system consists of two 150AH 24v batteries in parallel ( 300AH). I want to serialize these into a single 150AH 48v battery, then put the EG4 battery ( 100AH) in parallel to make a single 48v bank of 250AH.
There have been many posts that say this is not a problem, however Signature Solar told me it would "not be compatible". When I asked what would not work he did not give a very good answer. I suspect it's probably just something they don't want to support.
First question, am I wrong to do this? If so then why not? What will 'not work'?
If this is ok, then I probably need a battery balancer to keep the 24v batteries at the same voltage. I see many 4x12v balancers, but Have not found a 2x24v balancer. Does anybody have any suggestions?
Next question, If I put a victron smart shunt on the 2x24v bank, will EG4 recognize the battery as a separate bank ( it is probably an incompatible protocol)?
FWIW, I currently use solar assistant, It may not be necessary, but I'd like to keep using it. Can it be used to monitor the victron smartshunt ( second battery bank), and let the EG4 6000xp monitor it's EG4 Battery? alternatively, I suppose I could just put both batteries behind the smartshunt and tell EG4 is it one 250AH battery.
All batteries are lifepo4, and I am planning to use busbars. My cloud energy cl24-150 24v battery specs say they can be combined with themselves in parallel ( 4x ) and serial ( 2x ).
Any warnings/caveats?
Thanks
renogy 12v -> renogy 24v -> growatt 24v -> eg4 48v (I have lots of unused parts)
Thanks
