0truck0
I already have the system built, but wanting to add a monitor. What is the best way to go to monitor SOC of lithium with two systems, can I have one device for this? and sometimes I might connect the two systems together too in the event the fridge batt is too low, or if charging from truck alternator I can connect them together also (via positives).
I have two solar systems on the trailer. 200 watts through an mppt into one 200 amp hour battery. Times two, so 400x400 total. I can connect the batteries via a circuit breaker, and I did originally have all 400 watts feeding one 200 a/hr batt via the two mppt controllers, but when I added the second battery the real intent was to split the system into fridge power and everything else power.
Now I want to monitor the SOC. My old lead acid batts were easy, just look at voltage, but not so with lithium.
* the system. Chins 200 amp hour lithium. 2x100 watt glass mono panels in series (24v) through Epever Tracer 30A mppt controller. Two identical systems in the same trailer. The tow vehicle is connected to the one fridge battery through a circuit breaker that I just leave off almost always and that flows through a Renogy 20A 12V DC-DC Dual Battery Charger. The two batteries can be connected together via circuit breaker from positive post to positive post. The fridge runs straight off the terminals, but the other batt powers everything through the mppt controller "lightbulb" output.
