FWIW
When I received my new Mini's a few months ago, I was capacity testing them and discharging them individually on my system with 1000W heater. On the second battery I randomly added a large fan to the circuit and pointed in the direction of the inverter. I walked away and returned with a dead system and the inverter had failed with a low voltage alarm, but the battery was not discharged! F***! I could get the inverter to turn on but would not operate. I checked the fuse (but did not pull it out and look at it) and it was still in place.
I forgot I had entered an 80A mrbf on the circuit. The heater AND the fan apparently was able to exceed the 80A fuse rating. The fuse did fail however, upon closer inspection internally it was still attached with just the slightest of shard of metal clinging on to allow 9V to flow. Hence, the inverter alarm and failure. Replaced the fuse and all was well.
If only anecdotal - you have to expect the unexpected when it comes to protecting your system - whatever you choose to install or not install, choose wisely.
