May I ask.looks good. apparently your panels are outputting more than they are rated for. Which will happen when the panels are colder than 25*C(77*F)
I have 2 solar panels with d same spec's
120w x2
SCC display
Pv-33.1
Current is 8.06
I get 265.793 watts i worry if this good or not.?
Respect newbies..
120watts x2 = 240This looks like charging amps based on the arrow from panel to battery.
So if you are charging at 14V...
14V x 9.19A = 128.6W
The 32.2V pic that just shows a panel is likely array voltage.
What is your panel Vmp and Imp numbers on the label. In full sun, these should be your output (in reality, 80% is closer to reali
128.6W / 32.2V = 4A from your array14V x 9.19A = 128.6W
No you don't.I harvest almost 300 watts to my
120wx2 solar panel
Yuh. I understand that..No you don't.
Your confusion is reading the display. The volts reading of 32.3 is the panel volts of two panels in series at the maximum power point.
The reading of 9.19 amps is the current into the battery after conversion by the MPPT controller. This current is not panel current. This is battery charge current at a battery voltage of perhaps 13.8 volts.( lithium) or 14.4 volts (lead)
13.8 x 9.19 = 127 watts. 14.4 x 9.19 = 132 watts
With your two panels in series the maximum current, from the specification is 6.67 amps, so the reading of 9.19 amps is impossible.
Conclusion, the display of current is battery current, not panel current.
Mike
What battery do you have? Is that the manufacturer's recommended charge voltage?Lifepo4 battery - 14.4v?
This sounds like a preset charge profile.I put the parameters to lithium Li.
I UseThis sounds like a preset charge profile.
Is it possible that you can post your charge settings so we can evaluate them.
Or if you have a link to your SRNE manual, we can probably see the settings for the lithium profile.
Thank you very muchI think you will be better off creating a user defined charge profile.
Its explained here in posts 5-7.
My SRNE mppt drops to 2 watts after 10 seconds
Hi all, I'm new to the whole solar charging, powerwalls, off-grid electricity world and I love it so far. So my problem is that I recently bought an SRNE ML230-40, 30a mppt charge controller with bluetooth module that I hooked up to a 100 ah Lifepo4 battery. I also hooked up the charge...diysolarforum.com
