Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Copper like other metals will of course carry voltage, the amount of amperage capacity s relative to the thickness of said material, Aluminiun versus Copper for example. Material composition & purity affects those factors and can be quite significant, too much resistance / impedance and you've made a Toaster when enough Amps flows through there. If you can get an Infrared Heat gun (about $70 for a Ryobi @ Homedepot) and load out youe battery packs and then scan them, wires, connections, everything, hopefully your pipe - bars will be cool when pumping 100+ Amps. Test to the max load you can, you know, the worst case scenario you can expect. Better to know everything is 100% when your doing it under control and monitoring because @ 03:00 you likely won't be watching your system. BE SAFE !
