OffGridForGood
Catch, make or grow everything you can.
Yes, use the smart plug between - gives you easy controls and programing. heck you can turn it on and off anywhere with internet connection with your phone!
Battery and inverter must be a matched pair to be ul9450.I've got a call in to the solarpowerstore here in Canada... they're going to price out a small 5kW solar system for me (hopefully get the grant), and also a small maybe 120V inverter/small battery backup (14kWh I believe is the smallest UL9541 available ATM), and see what that costs.
I had started the Greener Homes Loan application back in March 2022, hopefully it's still open. I have reached out to them as well to inquire. If that is the case, I can get it covered by the loan...
In the process of looking at a heatpump laundry dryer, or a 110V All-in-one washer/dryer. GE has one in Canada. Can't find the LG or Samsung offerings yet up here.
Alternatively, I may MacGyver a system to cover a few of the evening loads on a 'portable' system. (Essentially removing 4-5 circuits from the breaker panel and switching them over to the inverter.
24V 280Ah DIY battery & BMS (6.7kWH)
3000W 120V Pure Sine Inverter (Amazon)
24V battery charger.
The battery and BMS are fairly straight forward. I would need a battery charger that can remember settings when unplugged/unpowered, or defaults to the proper settings when plugged in. Hoping to run the charger on a wall timer to capture the ULO rates. I figure if I can capture 4-5kWh of peak energy use, 81% efficiency in charging and inverting, I should save $245/yr on my peak rates. Assuming I can build it for under $1800CDN, payback would be 7 yrs.
The automated charging may not be possible, and if that's the case.... back to the drawing board.
Resiliency is the big reason togo with batteries. I switched over to the ultra-low rate last month. Charging my car is about free now. Solar panels recently installed, so don't draw from the grid during the day. Batteries smooth out the bumps...If you look at the super low overnight rate, plus daytime PV, it may take away a lot of the incetive to have batteries at all.
Winter storms and frequent power outages are my incentive for a large ESS system.
Let me know what you find outI'm currently trying to decipher the ESA code for ESS in Ontario.... some of it doesn't make sense....
field built battery can only be <1kWh capacity? what?
I would also have to put my electrical panel and inverter etc in a room with 5/8" drywall to make it 1hr fire proof.... I'm going to have to call someone and figure out if I can DIY battery in Ontario and pass inspection.
Let me know what you findI'm currently trying to decipher the ESA code for ESS in Ontario.... some of it doesn't make sense....
The code is not user friendly at all. We have to have a system that's certified for insurance on our new off grid home. They certainly do not make it easy. Local electricians don't seem to know what I'm talking aboutI have been following along on a CEC electrical forum, they are chatting about a new version coming 'soon' to the CEC, since many of the current requirements were drafted during a time before LFP was the common battery in the market.
Meanwhile per the Canadian Electrical Code a field built battery is supposed to be "less than 1kWh" capacity. (I decided innovation was not to be stiffled with regulation and did my own 'experimental' battery development - there actually is an exception for this btw)
My understanding is - no DIY battery will pass an inspection in Ontario/Canada under the existing code requirements.
I bought an EG4 Chargeverter - these are available from a few Ontario stores now, like Sudbury Solar.That was an option I was thinking of... Put the relay/solenoid on one side of the leads between the charger and battery.... That would interupt the charging... <-- I think that's what you're suggesting.
With some of the Ontario retailers (Sudbury Solar, Solar Power Store) are offering EG4 line of products, which are listed together with batteries, I wonder if you could pair up an EG4 6000 and 14.3kWh battery pack - put it in an attached garage?The code is not user friendly at all. We have to have a system that's certified for insurance on our new off grid home. They certainly do not make it easy. Local electricians don't seem to know what I'm talking about
Its whats called a base power station they can slowly increase and decrease the power levels but its very slow so going.Nuclear. Can't shut it down at night
Electricians with experience in this area are few it seems, or they have experience with huge grid-scale installs but not homes generally.
This old darling is BB blowerWe can all stop complaining about Inverter fan noise now!
Invest in yourself - do your own training.
That is why I am here! LOL
