Zwy
Emperor Of Solar
You will need a master breaker panel and a loads panel.Can you explain that a little more?
You have 200A service coming into your meter, then from the meter to a transfer switch. The switch can transfer from the meter service to the inverter/solar/battery service. So, the "out" from your inverter goes into the gen terminal on the transfer switch. The shore terminal on the transfer switch is the 200A service.
If that's all right, how do you charge the batteries from utility? You basically have the inverter "inline" in that configuration, right?
I can't really transfer circuits around, my meter base is ~200 feet from my breaker panels, so I would prefer this to be a "whole house" configuration and tie in right after the meter.
This is how mine is installed. https://diysolarforum.com/threads/e...s-diagram-correct-you-asked.56258/post-732148
If you want to tie in 200 feet away, it will get costly for wire as it would require twice the wire to be able to switch the transfer switch between grid power and inverter power.
I suggest adding another panel that is the loads panel, use your current breaker panel as the master panel. This wiring diagram is an example of how to wire in a 3 pole double throw transfer switch with a critical loads panel powered by grid or inverters. It would depend on how your inverter handles N-G bond that determines whether you need a 2 pole or 3 pole double throw switch.
