If you're using a 100lbs of propane a month, you're either heating a large RV or trailer without winterizing it sufficiently - and they have large windows, so that can be a task - or using the built-in furnace on an RV/trailer. Those stock furnaces are notoriously inefficient, having a heat exchanger only about 1/3 of the necessary size. A well-insulated 'tiny home' should go through no more than 40lbs a month. And that's stretching it - with cooking! Two BBQ bottles (20lb bottles, swap them at Walmart for $15 each).
I've been in a straw-bale 'tiny home' and you wouldn't need more than 1,500 BTU's to heat it, a 20lb bottle every 4 weeks. I mean in -20 fahrenheit with wind-chill. An RV can't touch that level of insulation.
