justinm001
- Dec 18, 2022
- 1,609
I'm finally getting into building solar array for my houses and confused on the order on how to do a self install. So far I have 4 pallets of panels and a SolarEdge 10kw inverter. This will be specifically for AEP WV (Appalachian Electric Power) net metering. My sole goal is to save on electricity costs. Do I install the panels and everything then hope they approve the net metering or do all the paperwork, get approved then start the install?
Looks like I can install without backfeeding to the grid which seems like an ideal situation so I can get all configured then if approved and new meter installed I can just reprogram to feed to grid.
Also I read that some electric allows net metering across multiple properties. I have 2 houses in WV, one has a massive roof perfect for solar while the other is horrible as a old home with all kinds of angles so likely will not have any or will just have a bit on detatched garages. On top of this I have 2 offices on AEP ohio but leased properties. I pay around $2000/mo for electric for all 4 spots at like $.10/kwh so if I could build as large as possible in 1 spot and have it offset the electric of other spots I could save a decent chunk of cash. Is this possible?
The properties are airbnbs that are mainly rented Thurs-Sun so I'll likely be installing myself or have some unskilled labor helping out and we'll have to slowly build over a month or two when its not rented.
I'm a bit concerned installing solar panels in the middle of coal country where there's literally a coal train stop in the small town for people to get on and head to the mines. Has anyone had a problem with anti-solar people? I haven't seen any solar around except there's an array with some odd wind turbine on top of the mountain way above our house.
