A word of warning for Outback inverter users. You should unplug the temp prob from your inverter if using lio*. You may find temperature compensation is charging your battery higher vs setpoints. Temperature compensating is hard set in the outbacks, Confirmed on my VFX and Radian. You should also calibrate your voltages with a known good meter and set the offset via the mate interface.
