Please stop mansplaining the videos, and respond ONLY with real world tests of a functioning setup producing Watts.Do you know what poly carbonate filaments means in 3d printing? Have you ever saw a print machine? Are you questioning the materials used for mechanical devices in the 3d printers? You make mistake after mistake. I forced you to recognize your mistake with my video of the outdoor test of the device because you did not even wanted to mention that you where obsessed thinking that the blades did not have movement and you come again with this statements questioning materials used in this industry? you are so angry and frustrated that I want to forgive this non sense commentaries as a consequence of your bad emotions because otherwise maybe your hole statements in this forum must be put under scrutiny!!!
Hedges inventing excuses about why he mistakes as a consequence of another mistake below,
(Hedges: Your later video clearly showed rotation. Maybe it was something about speed of image sensor in (cellphone camera?) and frame rate, looked to me like turbine was being buffeted back and forth. My mistake.)
There is a physicial reason of why you saw it static and your lack of knowledge pushed you to think that it was not moving.
It is because film is not an image of fluid motion. It is actually a sequence of still photographs, shown one after another 24 times per second (or 30, or 60, on TV and in video, depending on the format). The point is, when you watch a movie, you are seeing pictures in rapid succession one after the other. You brain isn’t capable of perceiving them as individual pictures (like a slide show) when they change that quickly, so it essentially perceives them as a moving image.
When film (or video) camera records a helicopter rotor spinning, it essentially takes 30 pictures every second. The rotor is spinning at very high speed, between 220 and 500 revolutions per minute. This means that the propeller spins between 3 and 8 times every second. Helicopter rotors have either two or four blades. So, a propeller blade passes above the tail of the helicopter up to 30 times per second. So, if the camera records 30 pictures per second, and the propeller rotates at the speed so that a blade will pass above the tail section of the helicopter 30 times in a second, the camera will capture that helicopter propeller in exactly the same position every time it takes a picture. So, if that rotor is spinning at just the right speed, it will appear on film as if it isn’t spinning at all. And if it spins just a bit slower, so that each time the camera takes that picture, the blade is further behind the position of the previous blade above the tail, it will appear as if the propeller is spinning backwards slowly.
You can see the same thing all the time in TV shows on car wheels. As the cars accelerate or slow down, the wheels seem to be rotating in all sorts of directions, and all sorts of speeds that are completely unrelated to the movement of the car. It is the same principle: film is simply a series of still pictures taken at fast succession.
That applies at eyes when viewing an helicopter for example.
I am dangerously close to closing the thread.
