wpns
Solar Joules are catch and release
I've got a Bad Boy Buggies 48V 4WD golf cart with eight Trojan T-145 batteries https://www.trojanbattery.com/products/t-145-6v-flooded-battery so 200AH(ish) and 576 pounds that I've been contemplating converting to lithium.
After noodling around with drop-in replacements (Allied Lithium still not ready for prime time plus 180AH is $4400) I realized that EG4 PowerPro is:
280AH
305#
Compatible with (identical to) my six house batteries, so if the golf cart dies I have a use for the battery.
'Only' $3800
There are a couple of issues:
1) Orientation. The default mounting position for home use is upright/vertical, but the golf cart would require horizontal mounting in the existing battery tray. The cells would be vent-upwards, so that's probably OK, but I don't know if there are any other real constraints on orientation. Would vibration be a concern? Does the IP65 rating depend on the orientation?
2) Charging. I've got a couple of ChargeVerter V2/GC that I could use, but the conversions (PowerPro House Battery -> 18KPV Inverter -> 240Vac -> ChargeVerter -> PowerPro Golf Cart Battery) offend the engineer in me. I know you can't/shouldn't/mustn't(?) connect charged batteries to discharged batteries, but don't the PowerPro have adjustable max charging current? In an ideal world we could just connect the two banks together with 10-25 feet of wire (which would have the added advantage of upsizing the house battery bank when connected).
Bad idea? Good idea? Brainstorm? Water On The Brain?
280AH
305#
'Only' $3800
