I have an AIMS 60amp Solar Charge Controller (SCC60-100A). I am charging two, 24v LifePO4 batteries (I am assembling the two batteries using eight, CALB 3.2v, 100ah cells). Fresh new cells
Parameters on the AIMS Solar Charge Controller:
PV operating voltage - 15-155Vdc@12V, 15-155Vdc@24V
Max. PV open circuit voltage - 155Vdc
Rated PV input - 24V 1700W
SanTan 250Watt PV Panels (SS270P-72):
Maximum Power - 270W
Open - Circuit Voltage - 44.4V
Voltage at Pmax - 35.5V
Short - Circuit Current - 8.25A
Current at Pmax - 7.60A
Max System Voltage - 600V
Fuse Rating - 15A
I have an older 3000W AIMS Pure Sine Wave Inverter/Solar Charger (I am not using the Solar Charger feature as it is not adjustable for LifePO4). 24Vdc in
What is the optimal serial, parallel config to string the panels to support my 24v charging, battery and inverter?
Fuse Rating - 15A
