Rednecktek
Solar Wizard
So now that I've replaced my laptop and gotten some of my data over, I can finally post some pictures of what I've been doing out here in the woods.
So when I bought this place the electrical system was seriously borked, and I didn't know any better. I knew enough to know that a piece of wet plywood with some BUSS fuses wasn't exactly a "Good Thing" but I was on an extremely tight time and money budget, so I did what I could with limited knowledge and more limited funds. Please remember that this system was re-built 2013, long before I joined the forum, so I plead ignorance! Don't judge me!
I SAID DON'T JUDGE ME!!
(I feel judged...)
So freshly finished with the long ugly divorce, and with a year's savings, I FINALLY got the chance to get back up here and re-vamp the electrical system. I started with the 12v side, the left side to be exact, and re-did all the wiring there. The battery cables are all the same length with proper terminals on 4AWG wire (because I had a LOT of it), a proper fuse block, and a properly sized disconnect. The 30a SCC talks to a pair of used 200w house panels outside to keep the system fed independently of whatever may be going on with the 120v power systems.
Next project was to actually USE that Growatt 3Kw inverter I've had sitting in the shed for the last 3 years, some proper wire, built a pre-charge resistor button, and put my battery box build together. I ran conduit and 8AWG wire to the interlock breaker from the utility power, a dedicated ground wire that's going to a bus bar and some grounding plates I'll be burying (once it dries out a bit!) and this will talk to a 2400w 3s4p array (again, once it dries out a bit!).
I'm currently in the process of clearing the land and dropping the trees for the array to go up. The 4x4's and 2x4's for it are already pre-cut and stacked up in the pump house. Unfortunately you can't brush cut or pull stumps in the mud.
Some more labels and clear nail polish to keep the labels in place and it should beidiot err jock err USER friendly to get turned on if needed.
More pics to follow once I can get to the rest of the array and trenching.
Yes, that's a diesel heater on the right hand side that dumps out at the head of the master bed.
(I feel judged...)
