Hi, can you tell me why Seplos equips its battery assembly boxes with a 400 Amp fuse. After all, the BMS is designed for a current of 200 Amps. Maybe it makes sense, for example, to change it to a 250 Ampere fuse?
Perhaps I didn't formulate the question correctly. I understand the purpose of the fuse, but I don’t understand why its value exceeds the BMS currentIf. My inverter's maximum charge and discharge current is 240 Amps, then why would I install a 400 Amps fuse. Is it logical to replace it with 250Amp?
