BTW - I tested the rapid shutdown functionality on my 6000XP today - turns out that the firmware update I did on my LLV2's a few weeks ago was primarily to add the rapid shutdown support and I didn't even notice. Once I made a connection for the rapid shutdown switch terminals, not only did the inverter output shut down (entirely - including pass through from the grid), but the LLV2 batteries all showed zero % SOC, and the monitoring portal showed BMS Charge and BMS Discharge as prohibited. The breakers on the batteries did not trip. Once I turned them off and back on again, it took a few minutes before they switched to allowing charge and discharge again. Now I'm not sure if turning the batteries off and on again was necessary or not. In any case, the LLV2's with the firmware update do in fact trigger the BMS to stop any charging or discharging. ?
Now back to finding a good switch for mounting outside by the main panel...
