For the van battery to DC-DC max will be 50 amps (25 amps max when solar is connected to the charge control) so 25mm2 wire will be fine.
I prefer to match the cable 35mm2 to the rated output of the house battery 200A even if you never intend to pull that current. What is the difference in price between 25mm2 and 35mm2 cable for the length ?
It gave me the option to add the inverter at a later stage, which I did.
A "Heavy-Duty Module Design Bus-Bar Box Terminal Board 300A w/ 4 Terminal Studs" on ebay in the UK is priced at around £25 GBP so adds about £50 to the build. For me it was worth every penny.
I don't have a circuit diagram but it is very similar to your diagram except for 4 x 160 watt Renogy solar panels. Based on Will Prowse's "
The Classic 400 Watt Solar Package" .
This is a list of the components I used
Description
4 x 160 Watt 12 Volt Monocrystalline Solar Panel RNG-160D-SS-EU
1 x Solar MC4 Y Branch Connectors MFFFF + FMMMM Pair RNG-CNCT-MC4BC-EU
4 x MC4 Waterproof In-Line Fuse Holder w/ Fuse (FUSE Amp: 20A) RNG-CNCT-FUSE20-EU
2 x 15 Feet 10AWG (6 mm2) Solar Extension Cable with MC4 Female and Male RNG-EXTCB-15FT-10-UK
1 x DCC50S 12V 50A DC-DC On-Board Battery Charger with MPPT RBC50D1S-EU
1 x 2000W 12V Pure Sine Wave Inverter With English Standard Socket R-INVT-PUH1-201235-UK
2 x 12V 100Ah Smart Lithium Iron Phosphate Battery RBT100LFP12S-EU
1 x BT-2 Bluetooth Module RCM-BT2-UK
1 x Monitoring Screen for Smart Lithium Battery Series RMS-LFPS-EU
1 x Cable Entry Housing RNG-MTS-CE-EU 1
4 x Solar Panel Roof Drill-Free Corner Bracket Mount RNG-MTS-CB-EU
2 x Heavy-Duty Module Design Bus-Bar Box Terminal Board 300A w/ 4 Terminal Studs
1 x Blue Sea Battery switch OFF ON m-Series 6006 IP66 master cut off isolator in RED
1 x ANL Fuse holder and 200A fuse
1 x Plastic Consumer Unit 12 way IP40 Distribution Board MCB RCD Din Rail Enclosure
2 x 63A DC Circuit Breaker MCB Solar Fuse 125v Single Pole 1P TOB1Z-63 C63
2 x 32A DC Circuit Breaker MCB Solar Fuse 125v Single Pole 1P TOB1Z-63 C32
1 x 25A DC Circuit Breaker MCB Solar Fuse 125v Single Pole 1P TOB1Z-63 C25
1 x 16A DC Circuit Breaker MCB Solar Fuse 125v Single Pole 1P TOB1Z-63 C16
35mm2 cable between batteries and bus bar
35mm2 cable between the inverter and bus bar
25mm2 cable between charge controller DC-DC and van battery via 63A MCB
16mm2 cable between charge controller MPTT and solar panels via 63A MCB (6mm2 cable from solar panels positive + to the MCB) (could use 6mm2 but I had a spare length of 16mm2)
Each of the solar panels has an MC4 Waterproof In-Line Fuse Holder 20A fuse on the positive side
Note that the Renogy 50A DC-DC with MPPT will max out at 25A for DC-DC and 25A solar when both are connected.
If you want the full 50A for DC-DC isolate the solar panels when driving. Useful in bad weather when solar is producing less than 4 amps.
