Rickster1978
I know this is something that my electrician will probably be able to assist with but I’m really keen to get my head around it before he comes over.
5.5kw Sunsynk Hubrid inverter and 15kw Seplos Mason 280 box are being fitted in the garage.
Feed from home consumer unit to garage is a 2.5mm armoured which I’m assuming is nowhere near big enough for the inverter / battery to be added to it.
On this basis I’m assuming it needs upgrading to a 10mm feed. However I’m not sure how easy I can get this feed back to the consumer unit in the house. Does it need to go back into the main consumer unit or can it be fed back to the meter without having to get back to the CU?
The meter is on the outside wall near the garage but my initial thought was that it would need to go back to the CU in the house if the battery is going to be powering the house during the day. Will be speaking to the electrician this week about getting it sorted but keen to have an idea so I can brace myself for a tricky conversation with the wife who has just redecorated the utility room which houses the CU. She’s not going to be happy if I need to start ripping plasterboard out to be able to get a cable back to the board
