those wires are very tiny, usually they dont grip firm when you only crimp. i usually make the copper strands protrude a little and then solder after crimping to give me a tight connection
I have a very expensive AMP crimping tool and the correct ring terminals made for 24awg wire. If I didn’t, I’d use the consumer grade terminals and solder them. In this application, both will give you good results.
