So I strung 16 LiPo batteries together after I had them sit in parallel for a couple of days and wanted to charge them mostly full so I could then top charge them with a small bench charger to 3,65V. I hooked up a Daly 16s 48V 150a BMS with all the wires conected and checked the voltage across the pins which all read almost identical at about 3.345 V . These are 230 Ah cells. It was real cloudy today and I hooked it to my Growatt SPF 12000 inverter and was getting about 500 Watts of charge and when hooked up there was 0V across the BMS terminals. I checked about 30 mins later and to my horror the inverter said the battery voltage was 57 volts. I checked the actual battery voltage and it was 53.6 and the BMS had something like 5 volts across it. After I disconected everything I found the second cell from the negative was at 3.66 volts and most were in the 3.4 range.
Any ideas what is going on here ?
