Hello everyone,
I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The goal is to maximize self-consumption and minimize grid dependency while incorporating new components.
Planned System:
Any advice on how to make this transition smoothly while ensuring optimal self-consumption would be greatly appreciated. Thank you in advance for any expertise or musings!
Current System:
- Wind Turbine: 5KW grid-tied
- Inverter: Windy Boy (No grid AC input)
- Connection: MCB -> Energy Generation Meter -> Isolator -> 32A MCB on the consumer unit (fed by grid electricity)
- Circuit Diagram: Attached for reference
Planned System:
- Solar Array: 8KW
- Inverters: 2x 11KW Hybrid Inverters in parallel (PIP MAX 11KW manual)
- Battery Banks: 3x 15KWH in parallel (Seplos Mason 280)
- Connection: The consumer unit will now be fed from the parallel inverters (22KW total). The AC input will be connected to the grid to keep the system topped up.
Requirements:
- The existing wind turbine must maintain a connection to dump excess energy to the grid.
Questions:
- Can the existing 5KW wind turbine still be connected directly to the consumer unit in this new setup?
- Could the wind turbine share the same AC inputs on the parallel hybrid inverters as the grid input?
