Randal Barrett
- Sep 24, 2019
- 8
Most lithium batteries cannot be used on most off grid systems because their built in BMS will damage their own batteries with series/parallel configurations. BattleBorn and a few others can be series/parallel with some having limits on number of paralles banks. BattleBorn says unlimited.
Some are still stating that lithium have a 80% to 90% percent draw down limit. This may be true on build your own prismatic or poorly designed lithium batteries with built in BMS, But is not true with BattleBorn and other well designed batteries! You get 100% of stated amp hours with BattleBorn! It will not hurt the battery to go to shut off voltage of 10v! When building your own prismatic batteries and adding your own BMS, yes you will lose some of the stated amp hours.
