Thanks Delta-V for the continued exploration & updates. I hafta say, been hesitant to pull everything out of the box, I was certain they glued the puppies in there too seeing how Glue Happy they got with everything else. LOL. Hmmm, I wonder if the gluer is getting high too ? might explain a couple of things. Pleased you got good numbers from the cells, were they also close to balance voltage ? Noticed they used different kinds of screws to attach the busbars on yours as well... mine has brass nuts on threaded brass hex-keyed threaded bolts. Not very consistent is also an indicator of mixed whatever's.
I'm assuming your still using their BMS and haven't replaced it yet, my
Chargery BMS8T should be here by end of next week, hoping the connector kit with ratchetting crimper and new copper Battery Bus Bars show up, I decided I did not like the "aluminium stock" bars they used either. Now that I know it can come apart easily, I'll be able to install the two temp sensors from the BMS into the pack. The conundrum is the strapping, I have no way to replicate the strapping and not terribly keen on using metal plumbing pipe strapping and I dunno anywhere I could borrow the tool to do what they did. Can't picture using huge zip ties LOL.... Any thoughts you have on re-strapping would be appreciated. I'm quite anxious to get into the update before testing & installation, hard really hoped to not have to go through all this and have it up & running, not sure if it will be ready to be online by xmas.... fingers crossed all parts come in !
BMS Replacement thread
