Small and decent don’t go well together for an inverter. But you may not need a quality inverter, it depends upon your loads. What do you intend to power with the inverter?
Then most any decent/cheap 1500W inverter will be fine. Probably even 1000W would do it (but measure your fridge's startup surge first). Giandel makes some decent-cheap inverters. EDIT - can't find their 1500W on Amazon right now. But WindyNation sells a good 1500W inverter, but it's not super compact (usually a good sign of better quality): https://www.windynation.com/products/vertamax-1500-watt-12-volt-pure-sine-wave-power-inverter
The 12v fridge won't need an inverter. An LCD TV requires very little power (depending upon size). You didn't mention a microwave, which is good, because those can be problematic to power from inverter, depending.
