Hi everyone.This is a picture of my new EV grade LF280K cells I bought from Gobel Power charging up for their first time.Notice the high AMPS this baby is taking at almost full charge and notice that the cells are basically balanced.I did not top balance these because Gobel Power website says if you have EV grade cells no need to top balance.Interestingly,my first charge shows that and all my cells came in at about 314AH according to the EVE report from my QR code.I would like to point out that I bought some EVE cells from Docan and cell voltages when charging are all over the place like my SOK 48V100,which my warranty replacement does the same thing after many cycles.lots of OVP, and cell OVP.My Docan cells are a set of 16 cells manufactured over 6 months apart.My Gobel Power cells were manufactured 72Hrs apart,and only about 4 months old when delivered from China and I bought 32 of them. the Ganfeng cells in my SOK 48V100 also have some cells manufactured a few months apart and they are older cells..My final report is my grade A Docan cells are not grade A(not EV grade) maybe grade B(old system naming).My Gobel Power cells are EV grade(thats grade A ++by the old system,better than grade A).The CCP dictated to do away with the grade A,B crap.Your cells are either EV grade or grade B or worse.If you have a PROBLEM with a battery or the cells you buy 1) your cells should be new not a year or more older or even 6 months old for that matter.2) The cells should have been made together like the same week.This means that the GOOP mixture they poured into your cell casing is uniform amonst all the cells you got,it came from the same batch.As much as I hate to admit it,my 280AH EV grade battery you see in the picture with the fancy wheels that will handle almost 600lbs is the cheapest battery I got.It cost less than the SOK48V100 battery and the 100AH batteries I got hanging on the wall in the picture AND it is a whopping 310AH over 3 times the AH of the other batteries.The EVE LF280AH cells from Gobel Power are better quality and will most likely last longer than the other batteries with less maintenence.Also the SOK48V100 battery warranty replacement and my Docan Battery,I fixed them they work good now too,just not as good as this LF280K one I built.Thanks
