Joske
Hello Everybody,
Problem:
After spending hours or searching in my installation and online i am a bit lost. Cannot find the reason why this installation (I have multiplel installations working) keeps showing weird anomalies in the data charts of the Online VRM environment.
Anomalie like;
-SOK Cel voltage drop,
-SOK Pack voltage drop,
-SOK totaal SOC drop or spike.
All drops in different parameters drop in the same timestamp.
Setup:
8x SOK - SK48V100
3x Victron MultiPlus-II 48/8000/110-100 230V in 3 fase.
1x Victron Cerbo GX
2x Victron Lynx distributor
Touque: Everything is touquet to specification as described by the manufacturers SOK and Victron
Cable: CAN cables is self made because of the length (5 meters) and measured twice if its wired the right way.
Programmed:
SOK batterij interface selected: Victron
What i am thinking right now:
-is maybe the CAT cable for the CAN interface between the Cerbo en SOK has to be shielded. The reason why i did not change this s is because it is a hassle to change it and thought with the baute rate this can't be the problem. But may be i am wrong. Befor sombody jumps on this train.....
Questions:
1-Has somebody had the same problem?
2-And what else than the cable is probably causing this?
I would like for somebody to show me the right direction.
Cel-voltage drop:
Voltage pak drop:
Spike in SOC
Problem:
Anomalie like;
Setup:
8x SOK - SK48V100
1x Victron Cerbo GX
Programmed:
Questions:
Cel-voltage drop:
Voltage pak drop:
Spike in SOC
