ab56452001
Hi all , Allan from OZ here . I have for about a year powered my Shed with 4 - 150ah no name AGM Batteries, running 4 - 300w Ebay Panels through Charge Controllers that came with the Panels , all this in Parallel . Up till now its worked great using a n Ebay 1500psw Inverter . This week i decided to add an additional 300w Panel/Controller , overkill ? probably !. Now ive hooked up the controller like the others B01 , 14/4v bulk charge , no load setting. I checked the Panel 22 volts , ok , but the controller does not seem to be running and putting out 3.5volts or thereabouts , is something wrong or does the Controller need time to adjust itself ? , by the way all other Controllers seem to be doing ok , at sit at 13,9-14,0 trickle charge and same for the batteries ,,,,, Cheers ,
