I recently installed the DIY 400 watt solar system shown in Will's YouTube video (major components listed below). I recently switched the panels from a parallel setup to a series group, as shown in the diagram here on his website. I am currently doing some testing with this setup, and noticed that the solar AH input shown on the MT-50 differs quite a bit from the AiLi Voltmeter (it was cloudy when I took this photo). Does anyone know why this might be the case, and which reading is the accurate one? I admit that I am completely new to solar and do not know all the ins and outs. I basically followed the blueprint. Photo shown below.
Major components list:
• 1 100AH Battle Born Battery
• AiLi Voltmeter Ammeter Voltage Current Meter Voltmeter Ammeter 100V 350A Caravan RV Motorhome 999 AH
• Power Inverter Pure Sine Wave 1200Watt 12V DC to 110V 120V with Remote Control Dual AC Outlets and USB Port for CPAP RV Car Solar System Emergency
• Bussmann CB185-50 CB185 Series Automotive Circuit Breaker (Plug In Mounting, 50 Amps, Blade Terminal Connection)
• WindyNation ANL Fuse Holder + ANL Fuse (2pcs 250A Fuse)
• Richsolar 4 Pieces 100 Watt Polycrystalline 100W 12V Solar Panel High Efficiency Poly Module RV Marine Boat Off Grid (4pcs)
• EPEVER 40A MPPT Solar Charge Controller 100V PV Max Input Negative Ground LiFePo4 Battery Charger W/ MT50 Remote Meter & Temperature Sensor Tracer4210
